Hauling question
khadux
If I haul (not towing) something that will weigh about 600 lbs, should I need an airbag for the rear suspension? I have the 04 v8 4runner. If yes, which brand of airbag do you recommend? Thanks.
Unfortunately, this would be a motorcycle that I'm hauling and it goes on the hitch so the weight would defintely be on the rear and the trip would be for 2000 miles and 4000 miles back and forth so they will be running hot at some point.
JUST HAUL AWAY, ADD SOME AIR TO THE TIRES AND JUST GO.
I HAVE HEAULED LIKE 2000 POUNS PLUS ON MY TRAILER UP THE NYS THRUWAY AT 80 MPH AND NEVER HAD AN OUNCE OF TROUBLE
MAKE SURE YOUR TRAILER HITCH HAS THE RIGHT TONGUE WEIGHT.
What kind of bike and what's the wt.?
You could always drain the tank to save a few lb's. Or you could remove the tank.
The hitch is rated for 500 pounds. I would be more concerned about that than an airbag. Maybe get a trailer of some sorts?
