I've got a 2000 with about 201k miles on it right now. So far the only things I've had to do to it has been replacing 02 sensors along with regular filters/fluids. The transmission fluid hasn't been touched since I got it with 160k miles because I wasn't sure and afraid to risk it invade it's never been changed. I tow roughly 1800-200lbs frequently and I've had a trans fluid leak on the rubber hose. I added some fluid last week and noticed my fluid is pretty brown. It functions 100% but I'd like to change it when I fix the fluid leak. Would it likely be ok to drain at this point and refill? Also is there an actual drain or just drop the pan? And does anyone know what size the trans cooler line is? I'm wanting to add a heat sink cooler and new fittings with the stainless wrapped hoses.
