have a ? on fog lights
  • Thread starter Thread starter burton6509
  • Start date Start date
B
burton6509
Guest
ok i question on fog lights.. i have a 02 sport and i bought it with no fog lights..but it has the swith and the harness to connect to..so will i be good to just order some offline install it with no promblems? or will i have to by more parts?
You have the switch already? That means you have either a Soprt or Limited and that it came with the fogs but someone removed them. So in that case you could probably just add the lamps. If you had a SR5 and it did not come with the Fog option then you would need to add the relay qnd fuse (and the switch) as well as the lights.
