have you ever used scan gauge?
if you find the data that it gives you worth the money, it seems like a good tool. Ive never heard anything bad about it, so i guess no news is good news?
I like that it can do MPG (idk how accurate it is) and volts (being in car-audio makes it a cool feature)
Overall though, for 164 (i think it is) its not a bad deal for the info it gives you, like i said, it depends on if you find that info valuable
What data does the 4runner report?
This looks cool, but exactly what info would the 4runner report out? Does anyone know?
Lou
Yep, have one permanently mounted in my Jeep, TONS of real-time data to be had, worth it's weight in gold, especially when diagnosing motor problems.
Other tools in the same category, ones that show the same data as this lil' sucker are FAR more expensive.
Check it out at www.scangauge.com
TRIP COMPUTER
Automatically tracks four sets of trip data - Each with 11 individually stored parameters.
* Maximum Speed
* Average Speed
* Maximum Coolant Temperature
* Maximum RPM
* Driving Time
* Driving Distance
* Fuel Used
* Trip Fuel Economy
* Distance to Empty
* Time to Empty
* Fuel to Empty
DIGITAL GAUGES
Display 4 gauges at a time from the 12 built-in digital gauges. the information is presented in Real-time!
* Fuel Economy
* Fuel Rate
* Battery Voltage
* Coolant Temperature
* Intake Air Temperature
* Engine Speed (RPM)
* Vehicle speed (MPH)
* Manifold Pressure (not available on some vehicles)
* Engine Load
* Throttle Position
* Ignition Timing
* Open/Closed Loop
SCAN TOOL
The ScanGaugeII allows you to troubleshoot your own car, read error codes, and the conditions present when the error occurred. You can also turn off the
