Having a Problem: ABS/Trac Control Kicking on Randomly
kaizer427
guys,
Would appreciate any thoughts on where to start on this one, i did a search but couldn't find anything that similar.
Randomly, and at slow speeds all of a sudden my traction control/abs goes off. There is a light on the dash but it goes out almost instantly, I believe it is the traction control lighting up and three beeps and a shudder through the pedals.
It did it for the third time today, all three times I have not been on the brakes. Twice I had just got on the gas after coasting to a slow roll and today it did it on a slow turn in to a shopping center.
When it does happen it scares the piss out of me.
Details on truck:
2006 with V8
99K miles
3 inch lift
The lift has been on for almost a year, this problem just started a month ago. It happened twice in the same day and then nothing until today.
Thoughts?
Hey there, mine did this last year! Always on the same turn. Anyways turned out I had 1 tire w low air pressure. Only 22 psi, other 3 at 40. Otherwise bad wheel speed sensor or wheel bearing could cause this. Check your tires first!
Jhunt
