Having an issue with my SC'd 4Runner running incredibly rich at low boost. Any ideas?
Renegade_Medic
I have a 99 Cali spec 4runner and I'm having some persistent issues with my 7th injector controller, specifically the closed loop fuel enrichment. The controller appears to be doing its job properly, my OBD Scanner shows that the trucks AFR is running lean and steady when the enrichment starts, which tells me the URD controller is doing it's job. I think. The problem is that quite often my actual AFR will go to around 13:1, like it's supposed to, then plummet down to below 10:1, where my meter stops reading. The trucks ECU is seeing a steady "lean" O2 to make it go rich, but it is just getting carried away sometimes, but not others. I'm getting really frustrated with this.
My suspicion lies in 2 places, one is a bad ECU for one reason or another that is not happy with the way the URD controller is working. The other is that I had an occasional P0420 code due to a high flow cat. I have recently put on the URD O2 simulator in an attempt to get the P0420 code to go away. I know the computer uses the rear O2 sensor to calibrate the front and I'm trying to rule that out. It is still going full rich sometimes. Gadget at URD has had me try a bunch of things and can't seem to figure out why it is only sometimes doing it and not others.
Has anyone else had an issue similar to this?
old thread i know, but [MENTION=147235]Renegade_Medic[/MENTION] did you ever get this figured out?
My s/c 99 with urd 7th is having similar issues.
very rich at idle and light throttle
kinda rich at partial throttle
plugs look worn (i'll change em soon) but happy
injectors will get sent for cleaning/testing as well
dont have an AFR gauge yet but upstream O2 sensor is switching quickly as expected with the rear O2 sensor switching slower and with much lower readings
You're not going to get an answer from him. From his build thread: https://www.toyota-4runner.org/3631944-post323.html
Try asking this in this thread: The 3.4L TRD Supercharger Thread
Philthyphilthy
