SCRunner12
I've been having some issues lately when I put my 4runner into drive first thing in the morning it won't move. I will give it some gas and eventually after a few seconds the 4runner will move slowly as if it's getting over a bump. After this the 4runner runs great and will go into drive no problem.
I also noticed that occasionally when I stop a bit abruptly at low speeds one of my rear brakes will lock up. It happened last week when I was going 10 mph and caused my tire to screech to a stop. Not sure if this is related.
I did some research and found people having issues with their e-brake cable binding.
Possibly the rear axle seals have soaked the pads and they are sticking.
The transmission filter is clogged and needs a drain and refill of the ATF.
The shift solenoids are going bad or sticking.
Anyone have any input on this? I looked at my rear axle and there is no evidence of the rear diff fluid at all. I will be pulling the rear drums off this weekend to check for fluid and check the e-brake cable. I have greased my driveshaft 5k ago, but haven't changed the ATF yet.
Another issue I noticed was my passenger rear shock has a thick film of black sludge on the forward facing portion of the shock. Any idea what that could be? The other side is clean.
Any help would be great. Thanks!
