Hazard / Rear window switched
AK602
QUICK QUESTION, HAS ANYONE EVER NOTICED THAT THE HAZARD SWITCH AND THE REAR WINDOW SWITCH ARE THE SAME SHAPE. ANYONE EVER WONDER IF THESE TWO SWITCHES COULD BE SWAPPED. I FEEL THE HAZARD SWITCH IS USED MORE FREQUENTLY THAN THE REAR WINDOW SWITCH. I AM SURE SOME OF YOU HAVE HAD THE DASH PANEL APART. ANY INPUT WOULD BE APPRECIATED.
the wiring harnesses don't have much room to move 'em around much. if you wanted to swap 'em, you'd need to cut the wiring harness to the switch and lengthen the wires...honestly, I kinda like where it is already, tho...
