:iagree:
Never reuse a torque-to-yield bolt. Because the bolts are designed to stretch once, stretching them a second time may stretch them beyond their yield point causing the bolt to break. They are one-time use bolts, so throw the old bolts away and buy new ones.
TTY bolts are usually installed dry. Do not apply any oil, grease, assembly lube or sealer on the bolt threads. The reason why is because lubricants reduce friction when a bolt is tightened. This actually increases the torque load on the bolt, which may overload and stretch a TTY bolt too far, causing it to break.
