runnyrunnerton
Im working on a write up for tracking down an oil leak and replacing head gaskets. Found the small leak under the back of both gaskets and have had no overheating problems. I was going to swap them out but i found out there is a kit that has all sorts of new gaskets. Includes Premium PermaTorqueMLS Multi-layer Steel Head Gasket.; Includes Premium PermaDry Molded Rubber Valve Cover Gasket.; Includes Premium Material Valve Stem Seals.;
hmmm. so do i need to replace all that while im down there? I really wanted to knock out my lower ball joints first. Timing belt and water pump were replaced around 40K ago so Im not worried about knocking them out.
Do i need all these parts? I wanted to go OEM on the 2 gaskets and valve cover seals and just change them out and be done. Dont think the heads need shaving as there has been zero overheating issues. But i am a do it your selfer not a mechanic.
she has 185K, 6 cyl.
