headlamp aiming
riceandpho
Elite Member
anyone knows how to aim the 07 4runner projector headlamps, i want to lower it a little, been searching and couldnt find a thing
yea, at the bottom, right between the low and high beam. i think my lights were aim to high from factory, unless someone here knows and have a diagram on how to set these things back to normal.
There are instructions buried here in the fourm including detailed instructions on how to set the factory spec headlight aim. I'm not sure if a traditional search will bring them up.
I'll try to find it after I read through your HUGE SIG! You should separate that thing into chapters
theres a small dot on the adjusting screw, i turned both of them to the 3 o clock position, seems like it lowered it a little bit, but i dont know if they are still high. should i turn it to 6o clock?
Try them out from a distance, like against a brick wall. You have to turn the screws a bit to get a few degrees of difference, and it's more noticable from far away than a wall up close.
