Headlight Adjustment- Central Texas
Ventil8
Member
I'm installing Morimoto Bi-Xeonon Mini D2S 5.0 projectors on my 2005 4Runner. I need to find a local spot in the Austin, Pflugerville, Round Rock area that has a wall that is straight and level. Anyone have any suggestions or tips for this installation. I've watched a ton of youtube videos on how to install but any advice from someone local that has done a projector retrofit will be appreciated.
You should do it where you can keep the truck parked in the exact same spot(don’t move it at all) so you can keep everything inline as best as possible. As long as you don’t move you just need to mark cut offs- hang a sheet somewhere if you have to. I won’t be level or far enough back to properly mark on my garage door, so I planned to just hang a sheet near the back wall and mark CO.
Check out hidplanet.com or headlight junkies on fb good info if you search on there
delislerebecca
