headlight bulb size
rydogg124
Hi guys,
anybody know what size headlights are in the 2011 TR4's? H9, H11?? I'm about to get an HID set from DDM. Sorry for the newb question, didn't find anything on the search results. thx in advance
Xenon Depot offer the H11 in various price points. The quality is superior to others xenon products i have seen / purchased.
I am very pleased with the workmanship, and fit.
On a small note, their kits offer 2 relays per setup. Others cut corners and offer you only one relay per setup, so if the relay goes bad you have no lights at all, whereas on the Xenon Depot system, you will at least have a working light.
Lastly, there bulbs were 'Straight" and not leaning like others i have seen.
my .02
I too have installed the Xenon Depot HID's and am happy so far, you will notice your Fog's will look silly and yellow in comparison so I switched those out as well. The Fog's are also H11 bulbs.
I plan on eventually getting some projectors as the HID's in the halogen housings is technically illegal, and do not feature great cutoff.
I opted not to use the included relays and just plugged everything into the stock set up, seems to work just fine.
You may need to re-aim your headlights when your done, I can tell that my left is sitting higher then my right side and needs to be adjusted.
re:
thanks for the info guys! I'll check out xenon depot, but I haven't had any problems with DDM. They offer lifetime warranty and their customer service dept is only 15min from me...
No One beats DDM's Prices. I've their Apexcone kit in my 4th gen for 4 years now. Most kits are made in China, then its up to distributor to determine profit margin. Just my $0.02
So I am curious to know is the H11 a headlight bulb and or a fog light bulb? or does the H11 refer to the base of the bulb?
