rpearlberg
I noticed last night that both headlights stopped working. When I turn on high beams they work, but no headlights.
Suggestions?
2001 4Runner
Suggestions?
2001 4Runner
Suggestions?
When I first bought my 4Runner, I noticed that swapping between high to low beam caused the low to not work. I took apart the combination switch and noticed corrosion on the copper electrical contacts. I lightly sanded the connections and haven't had an issue since. Try that.
Aren't the high beams and headlights just one bulb? Kind of weird that both bulbs stopped at the exact same time...
That is true. I replaced both of them at the same time, but is it weird that the high beams still work?A coincidence for sure, but not impossible as mentioned by IBallengineer. In addition to that, manufacturing processes being what they are today, the same bulb exposed to the same conditions would fail in roughly the same time period, that's why it's a good idea replace bulbs in pairs.
Bulbs are cheap and easy to replace! Always best to start with the simplest solution before getting too far into it to save your sanity!
In my old truck when the lights were near the end of their life they would only work in high beam. This was a feature to tell you that you needed to replace them. It was the same 1 bulb style as the runner.
Sent from my SM-N910V using Tapatalk
Would I be better off replacing the switch instead of trying to clean it? (if that is what's needed)
You've already replaced the bulbs and they still don't work? Well yeah, in that case it's obviously something else! The switch sounds like a good possibility in that case, especially if others have had that experience.
Although the high beam and low beam are the same bulb, they are 2 separate filaments, on 2 separate circuits. Unless you do all your driving at night on empty back roads chances are you're going to burn out the low first since it gets used much more often.
