It's there to keep the passenger side floor from heating up... I would go with Jetboy's fix.So I heard some rattling under my truck today and crawled underneath to find that the heat shield located above the exhaust system had come undone, so I removed it.
Question.......Should I replace it? Will I be doing any damage if I don't?
Thanks.
Mine loosenend up and wa creating a racket last year after a camping trip. The holes were too extended to bolt back on and the dealer even said it wasn't worth replacing. Off it came and no issues since.
had this problem last year and bent the shield (bending it changed the resonance of the metal). Sounds was significantly reduced, but it's back. URghhh FML. Makes my truck sound like a pile of crap. Anyway, hope this isn't a huge deal to replace. Not comfortable just removing it (it's there for a reason), replacing it seems to be the best thing to do. I'll take pics when I can........
I'm going with this solution. Took mine off today. If I never report back, you'll know I blew up!![]()
So, a good couple years have rolled on by and still working like a champ!!
.................I'll take pics when I can........
Make sure you check the gaskets in the exhaust pipes. I had that too. Swapped out the old gasket (which disintegrated) and it went away. Total cost of the new bolts, springs, and gasket was something like $25 and took about 20 mins to do.I've had to bolt my heat shield up there twice before. Gotta love the NY winters. Now I have another rattle around 1300 RPM and it's not the heat shield.Sounds like a baffle has rusted loose or something in the muffler... we'll see what this once costs in $$ and bloody knuckles.
