Heated mirrors???
When your mirrors and your windshield are fogged up, turn on your defrost. Your mirrors and winshield should both clear up. That's what mine does.
Thanks! But i normally turn my A/C on when my windshield gets fogged up. It clears faster with the A/C on than the heat. Also, i don't recall seeing my side mirrors getting fogged-up. :confused:
Switch on your rear window defroster. If you have heated side mirrors the mirror will get a little warm. Place your hand on the side mirror and you'll feel it warm up. Might not work if it's 100 degrees outside, but you'll feel it if it's in the 70's or below.
when there is mist on the mirrors press the rear defrost button. if you have the heated mirror option they will clear in a square pattern within one minute
so you dont have to wait for them to mist up or anything...just poor some water on them and turn the rear defrost on.
If you've tried the tips mentioned so far and still can't finger it out :D, it's easy enough to just pop the glass off and see if it's got wires going to it. If there are wires going to the glass, you've got heaters.
i'mma afraid to pop the glass out, i might break it. But someday i wanna install one of those turn signal sidemirrors.
Its really not as hard to remove the mirror as you might think. I just replaced my mirrors with heated ones from A/V1. The replacement time was fairly quick and straight forward. If you need a diagram, check out Burtman's site for instructions on how to replace the mirrors with Muth signal mirrors. I didn't even come close to breaking mine. Try it Mikey, you'll like it.
patnewton
