Heater in Recirculate mode always on startup
JPNNH
Every time I start my 06 4runner the recirculate button is on... no matter what my temp is set at...Is this normal (pain in the a**) or is there a problem with my system?
I have an 06 too and mine does it as well. I have gotten into the habit of hitting it every time I get in the truck. It is a pain in the ass but I don't think there is a problem.
I've noticed that the auto climate control does that for A/C, but haven't seen it for heat too. I'll have to watch it.
The reason it does that for A/C is because it's more efficient to cool air inside the car that's already been cooled. Until the A/C system gets fully up to speed, it would have an ever harder time doing anything useful with outside fresh hot air.
Don't worry - if you had it on outside air before you shut the car off, then the computer will go back to outside air as soon as the system is up to speed. You don't need to change it.
JPNNH said:
It happens even when the AC system and the AUTO climate control is off...
Never noticed this on mine. I don't think mine has ever switched over to recirculate automatically.
I've only noticed this when my system is turned off. If I leave it on AUTO with A/C off if never happens.
If you leave it in AUTO, then you don't have any control whether or not the A/C is on or off, correct?
It seems to me that AUTO turns the A/C on and off automatically.
In AUTO mode, if the A/C button is on, then the computer will turn the compressor on and off as needed. You can turn off the A/C button, and the computer will accept that. Of course, it won't cool very well or dehumidify the air.
AUTO mode is just like the thermostat in your house - you don't control the temperature of the air in the vents; instead, you're asking the car to do whatever (heat or cool) to make the inside that temperature.
Yeah, but in AUTO mode, it will turn the A/C on if it needs to cool the air, right? In other words, it seems that my 4Runner will not allow me to control whether or not the A/C is on or off when I'm in AUTO.
BTW, I don't usually use the AUTO mode. I prefer manual control. That's why I'm not too sure how the AUTO mode really works.
While in AUTO mode, you can press the A/C button and the A/C light goes off without dropping out of AUTO mode.
I believe it will respect your request to cool by blowing fresh air without the A/C compressor.
recirculate mode a new option for '06?
Is this option new on the 06 runner? Does it allow to recirculate cool air in the seat of both the driver and passenger?
Thanks,
Re: recirculate mode a new option for '06?
Thanks,
No... the seats won't do that. We're talking about the recirculate setting ("inside air" vs. "outside air") on the heater/air conditioner system.
Re: Re: recirculate mode a new option for '06?
Thanks Toto,
I went out to lunch with a friend who has an ES330 Lexus sedan. I was impressed when I felt the seat cool down. A nice feature that I have not seen in the GX or 4 Runner but would like to own an SUV that had one.
Cheers,
I've been meaning to post about this annoyance too. In my truck, the recirc comes on constantly when I have the air temp set to "LO" even with Auto and AC off. But if I increase the temp just one notch, this doesn't happen so I leave it on 65.
Welcome to the wonderful world of the 4Runner HVAC system.
CV
Yeah, I just realized this tonight. I had been reading this post for a couple days trying to figure out why it's always on recirculate when I start the truck. Figured out that if it's on LO, it will be on no matter what. As long as there is a temp reading above LO, and the recirc button is off when you turn off the truck, it will stay off when you turn it on again. Was kinda puzzling to figure out at first.
There have been many, many complaints about this "feature" since the 4th gen trucks appeared.
Our '03 will do it irrespective of the settings of any other HVAC controls. Whether or not recirc gets switched on seems to depend on cabin temp being above some set point. This leads to the absurdity of getting into a truck that's baked in the sun on a cool day, needing to have fresh outside air in the cabin to cool it off and finding the truck has switched itself to recirc!
As great as the rest of the 4Runner is, it puzzles me that Toyota
(a.) Designed such a klunker of an HVAC system, and
(b.) Has neglected to fix this obvious design goof over succeeding model years.
I'd guess a simple software change would do the job.
