Heater Speed Swich Problem
Stillrunning
My heater only works on high speed.Is there a resistor block that has failed? What would cause this?The selector switch goes through all positions but does nothing except at the high position.It's a 92 4Runner with air conditioning.
It's most likely the fan speed resistor module. It's located in the ductwork under the dash, pass side.
Just did mine the other day. Had the same prob, only worked on high... Got one off e-Bay for $20 shipped... I peeled the carpet back a bit to make a little more room, its close to the firewall in the ducting..
