Heavy vibration at idle
fluffeh
I've noticed recently that when I'm in gear at idle, my car vibrates a LOT more than seems normal. If I shift into neutral, the revs go up by ~200 and the vibrations go away. Every time I stop at a red light I get this annoying vibration, and it's starting to make me worried something has gone wrong. The only mod I've done to the entire system is a Magnaflow muffler, so I don't know what the problem is.
Wouldn't a misfire trigger a check engine light?
I was thinking the mounts but I wasn't sure because at slightly higher revs it goes away and I thought it would be the other way around if the mounts were worn.
CoaterZ_FL
