Dezert4Runner
Senior Member
I've been meaning to do this for some time since I've had these lights sitting around for a while. I thought it would be a better option than leaving them on the outside of the grille on the floating light mounts I had fabbed up a couple months ago right after buying my runner.
Here's the floating light mounts that I had going that I was too worried to leave my lights mounted to for security reasons. You can see them sticking out inbetween the grille & the bumper.
After seeing BLCKTPGSR's build thread where he did something similar with some PIAA's, I was determined to do that with my Hella's.
Here is BLCKTPGSR's PIAA's
I shortened the ends of the floating light mounts that were coming out the front, and took a jigsaw to the grille to cut out the shape of the lights. It took me 3x as long as I thought it would. I'm going to wire them up by the end of the week (working full time sucks when your mod list is longer than you're available time). I've had a factory fog light switch sitting in one of the available blanks in the dash, so I just need to find some time to wire them up.
Top view
I sprayed the covers with Plasti Dip so they would look a little more low profile, but I suppose I could always peel it off if I don't like it. I didn't realize how much of the grille material I needed to remove, and if I were to do it over again I would probably go with the smaller Hella 500's or similar for ease and overall fitment reasons, but I'm happy with the end results!
:cheers:
Top view
:cheers:
