Hella Supertone Wiring question (97)
DC2LA
I've got a 97. I cut both plugs to the OEM horns. There are 2 wires on the driver's side horn while only 1 wire on the pass side.
On the pass side i connected one prong to the existing wire and grounded the other prong to the bolt which mounts the horn.
On the driv side i don't know what to do with the two wires. I tried connecting the wires to the horn in all combinations and only got the pass side horn to weakly beep.
Any suggestions? Help? Do i need to use the Hella Relay instead of the OEM? What are the two wires? Help.
Thanks.
Not sure about the wiring on a 97 but if there's a little bit of power from the existing wiring, you'll have to use the relay that came with the horns.
