billsheila
Well I am the proud owner of a 1999 4Runner SR5, but with a problem that has spilled over from before I started ownership!! I am hoping I might get some help. When I first looked at the car the owner disclosed he had been having trouble with hesistation and CEL coming on. The rest of the truck looked fine so we agreed to a price subject to him fixing this issue. The saga began. Long story short he is into it for the following:
New O2 sensors (not sure if they were aftermarket or toyota)
that didn't work so
New MAF sensor
that didn't work so
New fuel pump
They said "its fixed" so I paid the guy for the truck and picked it up (He paid for all of the above :violin:. Not 20 minutes into my new ownership and I have the same problem. It isn't throwing a code or throwing the CEL light on (although it did this in the past and it was P0171 "Lean Bank 1" when the prior owner brought it to the shop).
I have searched this site for help with that problem and it seems like a variety of things it could be, anything from the above items that were changed (which were obviously wrong) to the ECM, injectors, temp sensor, Throttle position sensor?
The only way I can describe the symptom is to say that it seems to occur if the truck is sitting idling for a while. The idle then drops real low and it starts to run rough. Then when you go to accelerate it just dies...still running but engine is making some popping noises, no power it just crawls along....then if you keep the accelerator pushed and pump it a bit, it seems to break through the dead spot and clear itself up. It has happened a few times but when it isn't happening, truck seems AOK and again no new codes or CEL these last few times. Once you get through the rough spot it will seemingly run fine. So far for me anyway it seems to only do it after a fresh start.
QUESTION FOR THE EXPERTS ON THIS BOARD:
What should I try next?
I was thinking the temperature sensor, because this is listed on the P0171 code helper that I read and my theory is it seems to happen when it is sitting, then is started and warms up? If not that maybe the TPS next? These two bits seem easy enough to change, but I have no idea how to test or change an injector.
Mileage 110K. Any help would be very much appreciated.
Thanks. Newbie
that didn't work so
New MAF sensor
that didn't work so
New fuel pump
Thanks. Newbie
