Hello motor cutting out
calvinv8sr5
Well just like the title, drove about two miles this morning, went to pull out on a main road and almost got hit, no power, then power would suddenly come in. Took a long time to shift like it want getting gas.anyone have a similar problem.
2003 Toyota 4runner v8 2wd
167k timing belt done at 100k, I know i have Mus fires on two cylinders, maybe those cheap ass coils thr po put on are going out
All we can do is just guess at what is wrong,i would find a good repair shop "not a Toyota dealer" and let them do a complete check of all systems.
This way you will be money ahead and will get it going again.
If you just start replacing parts,it will end up costing a lot more.
Well I know now that atleast two of my injectors are not working, unplugged coils they're firing, unplugged injectors two made no difference in how it ran so they're bad
Any chance the VSC was activating? If the zero-point calibration is off, turning very sharply and quickly could activate it and cause the symptoms you experienced.
Well after changing the fuel injectors, cleaning all the contacts under the hood, and greasing everything, she's alive again, after testing the injectors pretty much all of them were fvked. On a sad note cel went off and it rand beautifully for 5 minutes, then sit it off and drive it again cel flashing.... skip...... wtf
I know before it was miss fire cylinder 7&8. Coils are good, plugs have grease, spark plugs are new
Alright then, go rent a fuel pressure test kit that has the metric banjo bolts and find out the Fuel pressure in the rail. Check out my thread titled Holy DTC codes hell for info on fuel pressure stuff. Quit throwing parts at it and be systematic.
10_4 will the generic tester from AutoZone work?
Seriously made me read 11 pages to see a link for a vvt v8... next time mention that's its on page 10!!!!!!jk thanks for the info, I'll check it out soon
Lol, I wanted you to understand the banjo fitting thing used for fuel pressure reading. Not all kits have the metric banjo.
charlesz
