4RUNNER_2004
I just changed transmission oil this afternoon. it was the first time do this work.
I got things that really confused me. Please help
ok let me tell you what I did.
first all I pulled out the fill plug. 2,pulled out overflow plug, there're about 1.5L oil flew out. 3, pulled out drain plug there're about 2L oil came out. so I gout about 3.5L drained out.4, filled about little less WS 3L( only bought 3L). 5, followed what I learned from here
http://www.toyota-4runner.org/4th-g...r-ways-check-ws-transmission-fluid-level.html
shift gear to all positions, and idle for 20 min. 6, pulled out overflow plug, I got 1.5 L oil.
if I over filled 1.5L on step 6, It must overfilled before (last owner changed @ 91,914km at Dealer ) see step 2. right now I have 160900km if it was overfilled why didn't cause any problem.
when I asked a guy at Part Department of TY, he said there is no overflow plug. it's another drain plug, because it's a big pan need two drain plugs, and it's on the bottom, overflow plug would not on bottom. what he said sounds right too.
so please help me, it's a overflow plug? or not? did I over filled or under filled(drained 3.5L, filled 3L). I don't know if I can drive it or not.
I would really appreciate you help.
