Help: 964R Loose Driver Side Mirror
rjat58
Mirror had been fine. Shut door and mirror spins loosely. Won't lock into place. Any known fixes - bolts to tighten?? Any insight greatly appreciated.
Thank you Habanero . I think I may have lost one of the screws from the bottom of the mirror housing because it won't stay in the normal position and just travels freely in or out. So I'm thinking that may be it, but I dunno.... LOL
That sounds reasonable. The access hole for the most likely- and easiest to get to- culprit is at the bottom of the mirror housing, below the mirror. Just be careful not to strip out the plastic screw hole. It's possible the screw is still there since the assembly hasn't fallen out yet. Good luck!
AndiGarage
