HELP!!! Advice needed before i install my new lift
mrwinkle13
So I'm copying THIS build and i have ordered all the parts; however, I neglected to note the fact that this is a V8 and i have a V6. Also I have the toytec 1/2" spacers instead of the 1/4" and my wheels/tires are P265/70-17. so these are my questions. Do i even need the spacer to acheive the same stance since mine is a V6? I am about to install a Metaltech tube bumper and a 60lb winch so this should be factored in as well. If i do use a spacer will the 1/2" be to tall without new UCA's and will I nose high or level? I dont want to install everything and have to redo it. Thanks in advanced.
I would go with the 885s without the front spacer. You'll get over 3" initially but should settle some with the bumper. 3" is really the limit without aftermarket upper control arms.
I have the same front setup and you should be fine since you're planning on the extra weight without the spacer. My front end is definitely stiff without the weight, but I love the way it drives on and off road. Worst case you can crank up the 5100 a notch if it settles too much for you. I went 885s because I knew I'd be getting skid plates, sliders, and eventually a dual battery setup and a bumper.
