Help/advice on front lift + rear leveling + tire size
CaptainCrump
I'm looking to give my 2005 4Runner 2WD Limited some body. Considering a 2in lift (suspension or body?) in the front, & a leveling kit in the rear. I have Inkey rims (17 in) of which I'd like to keep on her. My current tires are on the verge of "got-to-go" due to cracking in the wall. I've never been through this process before & would really appreciate some fellow 4Runner input.
*Size & type of lift in front
*Leveling kit in rear
*Size/tread/brand of tires
*Any additional ideas
Thank you!
I think you will find a ton of info in the suspension/lift FAQ at the top. In there everyone discussed most if the available options with relevant tire sizes.
Thank you!
A levelling kit is usually nothing more than a mild front lift. It's called that because from factory the front end is usually much lower than the back.
A body lift can't be installed on just the front. It's an all or nothing kind of thing. If the goal is a less than 3" lift most guys do a suspension lift.
The most common and cost effective combination seems to be a Daystar spacer lift for 2.5" in the front and 1.5" in the back with 265/70/17 tires. Goodyear Duratracs and BFG A/T T/A tires are the most popular. If you're shocks and struts are still good you can stick with them or you could swap them out. Bilstein 5100's or OME are popular.
lindwlson982
