Help asap
CanuckinTX
Asking for a freind he needs help and quick.
Brakes are hard as a rock, ABS light is on, VCS light is on, Brake fluid reservoir is empty and brake light is on.
I will update as I get more info.
Fell free to text me four6nine-4zero0-four9eight1
Add fluid and try to bleed the brakes? That's where I'd start. Air in the master cylinder may be no fun or you could get lucky and get brakes again.
I think you need software to bleed the master cylinder. Also the empty reservoir is pretty concerning. Leak somewhere?
Brake fluid doesn't evaporate if it's empty he has a major leak somewhere, I agree find the leak, repair, bleed system and hopefully all will be well....BUT the hard brake pedal is a bit confusing, I had my brakes fail, I had a full pedal and within 3 to 4 city blocks and using the brakes 3 or 4 times I went from the full pedal to no pedal or brakes at all, it was on Thanksgiving day 2 years ago 7:00pm and nothing was opened, I drove 90 miles home using down shifting and the parking brake when needed, made it home OK, I figure the master cylinder went out and at the time didn't know how these T4Rs brake system/master cylinder worked, thought it was the normal type system, I was very shocked to find out how much a master cylinder costs, popped the hood and saw I had no fluid so I then looked underneath and found my front left hard line was broken because the bolt holding it to the steering arm was snapped off and over time from just making turns the line broke from the small amount of flexing, replaced it bled the front brakes and all was good.
So him having a hard pedal seems to also point to another issue, but it could be hopefully just a leaking line or caliper.
Brave (or crazy) man. 90 miles with no brakes...
Well as mentioned it was Thanksgiving evening and not many other people on the road, mostly rural highway miles, maybe 10 or so traffic lights, but slowing down ahead of time, down shifting down to 10 MPH or so and then using the parking brake worked much better than one would think, no real issues what so ever, and not to mention I had no other options in my mind under the circumstances, I wasn't going to leave it on the side of the road and walking 90 miles from home and having it towed wasn't happening, not paying that bill ever!
If it was any other time and traffic conditions I would have left it and called my daughter to drive me home and then borrow my neighbor's truck and big trailer to go back for it.
Fixed
Thank Yall for your help. It ended up being that somehow the Brake pad fell out and the psion pushed to the rotor and the brakes drained.
charlesz
