piperoo
I am trying to hook up a switch to allow my antenna to go up since Pioneer doesn't have an antenna wire on their harnesses. This switch has 3 prongs, an "Earth", "Supply" and "Load". First, can someone clarify what those are? I was taking "earth" to be ground, "Supply" to be my antenna wire from the 4Runner and "load" to be my power wire.
So I hooked up the power wire (I spliced the power wire going from the 4Runner harness to the radio) in order to get power. I blew a fuse and now the radio, clock, etc will not come on. I looked under the hood and didn't see where the fuse might be and pulled the lower left kick panel on the driver's side but those are pretty small fuses.
Any information would be great. Not sure why I would have to run a power to get the antenna to go up and down..thought I could just put a 'toggle' switch but with the switch I have it wouldn't work.
Thanks in advance for the help!
