Help - Broke one of the studs on the upper plenum where the throttle body attaches
TLGG
Help a rookie out - what are my options for fixing this? I hope I don't have to buy a whole new upper plenum..
Pretty sure you can buy just the stud, it’s threaded into the upper plenum. Can get it out with a pair of vice grips most likely. To get the new one in you should use the double nut technique though.
Edit: I think this is the part #9011608159 not 100% sure though.
Thank you so much for your help. As you said, it was threaded to the plenum so I was able to pop it out. (Thanks for the part # as well)
Philthyphilthy
