sixgun86
When I first bought the vehicle it had a misfire on cylinders 3&5 with slightly rough idle. Smooth power under load. Looking at the plugs from 3&5 the gap was off. Almost touching the electrode. I replaced the wires and plugs, ran some injector cleaner. CEL turned off. Fixed the idle.
Week ago I was playing with the ECT while making a pass and the CEL came on again. This time it flashed. Threw of P0171 lean code. I proceeded to clean the MAF. Code went away.
Today, CEL came back on. Misfire cylinder 5 again. It has a smooth Idle. Smooth power under load. Wondering what to do now.....?
New wires
New NGK Plugs
Injector Cleaner
MAF cleaned (properly)
Switched coil packs around
Clean Oil, No loss of any fluid.
New wires
New NGK Plugs
Injector Cleaner
