Help finding rear ABS harness
jms2112
As the title says, I need some help finding a rear ABS/speed sensor harness for my 2005 4Runner, V6. The one from near the drive shaft to the wheel. I'm not sure if it is one harness that goes to both wheels, or there are two, one to each wheel. The wire to the right is damaged.
I have searched eBay and can't seem to find any that apply to my vehicle, or are the rear. I'm trying to avoid the dealer to save cost.
help! thanks
Actually I don't even know if I can get it off. The connector is way up above the frame rail.
Does anyone know of a way to test the continuity of the wires? i.e. where does it go to up front? I'm figuring in the ECM somewhere...
thanks
ok, I think I found the skid control ECU
does anybody know what wires to test to check the wheel speed sensors?
thanks!
done
Glad you figured it out. Posting info like you did is key fir future members who search based on similar issues.
thanks
IT'S DONE AND ALL THE LIGHTS ARE OFF!!! took it for a quick drive and the lights turned off. That is a nice feeling.
I cut a new end at the connector and jammed it in and it is holding good.
The digital multimeter was indispensable for this. Couldn't have don't it without it.
extra info
here is the connector to the speed sensor:
with the broken wire.
here is a partial schematic of the abs circuit showing the black and white wires from the RR sensor
If anybody needs help on speed sensor troubleshooting I'm your guy!
Dude! So old of a thread but you saved me big time tonight. Tore my rear abs sensor wires out of the connector when installing rear springs and was in a panic. T4R to the rescue, thank you! Connector has numbers on it so I was able to depin, solder wires back to pins, and repin in correct orientation for no faults.
Sent from my HTC6545LVW using Tapatalk
How did you get the pins out? Brute force? Mine aren't budging and I'm afraid of bending them too much.
Sorry to bring up an old thread but can you or anyone tell me the correct orientation the wires go?
Jhunt
