Help identifying mystery plug on 5VZ-FE
rickmum
Member
Hey y'all,
So I noticed this for the first time yesterday and I'm having a hard time figuring out if something's unplugged. I have no CEL.
This is right behind the inner wheel well on the drivers side, under the exhaust headers.
1998 Limited with rear locker.
Edit: found more... What the hell is going on here
Hey y'all,
That 2nd one looks like the Oil pressure switch
The first one I dont know
Looks like you are in serious need of some VC gaskets and seals.
Stock oil pressure sensor (the one close to the filter)? The other one I would have to crawl under the T4R to give an opinion.
Being a Canadian I got the first one!
That's an add on block heater that sits in a frost plug port. Yours is currently missing it's cord. I put one of these in every car I have owned.
I'd also check around the oil cooler. It is low on the drivers side of the block, and is prone to leaks. Mine made a mess of that side of the block, steering rack, etc because of a bad o-ring and washer seal.
Sent from my RS988 using Tapatalk
I had a ton of old oil all over the steering rack too. I just tightened every bolt on the VC, they were all so loose I could manipulate them by hand.
Gave the side of the engine a good scrub too so I can watch for more oil.
seltzernator
