Help me choose a 4th Gen
Definitely look for a 2008 or 2009. I assume you will be driving in a lot of snow. The 08 and 09 come standard with the ability to disable the VSC and traction control.
The limited trim 06 or newer will have your seat position memory buttons...
Yeah, plenty of snow. I assume a 2006-2007 only disables traction control in low range, then? I guess that isn't a bad compromise?
Does that handle mirror position as well?
A.
A.
On the 03-07, the traction control is disabled when the center diff is locked. I can't remember if it is locked in 4L also... but most times when I used 4L the center diff was locked anyways...
I believe the mirrors and drivers seat both adjust with the memory buttons.
