Help me pick the lift!
Mike07SE
Right now I'm torn between two lifts that I'm looking at. The first is the Daystar setup (with the top out and pre-load spacer), and the second being from Toytec which looks to be about the same front setup with the pre-load and top-out spacers and comes with replacement coils for the back. Here's a link: ToyTec Lift Kit.
Quick details: I have new tires already that I got off a friend. BFG A/T's 265/70-17. I do go wheeling. Try to at least once a month. Truck is also my daily driver. I do carpool and commute about 65 miles a day for a week every three weeks. Just thought some of these would answer q's in advance for some of your inputs on how I use my 'Runner.
If you all believe the Daystar is fine for around $150 then I'll go with that. If the ToyTec lift can be justified for it's $300 price tag and the extra $150 in improvents over the Daystar, I'll swing that. My budget is a little tight (whose isn't these days?) so I'm trying to be modest right now. Down the road in maybe two years or so I might be going with a front coilover of sorts, but that'll be then.
A10MileHusker said:
TOYTEC, TOYTEC, TOYTEC!!! :bigok: :D
Only because I just bought a Toytec lift and the customer service is unbelievable!
I am going to give them a call also , I only want like a 2/1 lift and I want to see if the have CO solutions instead of spacers. Although it may last a while ....never know , but with the miles I have was just thinking of yanking the Xreas , bolt up new kit in front and back , add some bar bushings and be done.
What lift did you order >?
Daystar is on the way! Hopefully it'll hold me off for a while. Got my BFG A/T's put on today. Lovin' the looks so far!
