help me with suspension ideas
byro58
if i want to do a 4" lift whats the best way to go? whats the difference between a 4" suspension lift and maybe a part suspension part spacer lift?
read up
see the SONORAN STEEL website for a wealth of info on lifting the 3rd gen Runners.
look over the FAQ section of the 96-02 lifts.
4" is a little too much.
3" is about the max recommended suspension lift.
Avoid spacers depending on who you ask.... poor ride quality and worse for off road.
You might consider a 1" body lift with a 3" suspension lift to achieve same results.
Ditto, the spacers make the ride firmer/(harsher) which only improves handling on road. The spacers make the rider harsh off road and limit suspension articulation. I will be replacing my spacers with a coil lift all around when I have the money. So if you only drive on the road, spacers are a good choice.
Any of the 3" suspension lifts and a 1-2 inch body lift are pretty easy to do and can accommodate 33's easily.
Just thought I would give the opinion of someone that has spacers. Does the job of lifting but doesn't improve off road performance besides ground clearance. I would get a coil lift and new shocks too.
