I've been a lurker here for a while, but never had a need to post.
Here goes:
I decided to seafoam my 4runner the right way (I had used the brake booster line in the past), and when I tried, I realized there was no suction on the hose that goes from the pcv valve to the engine (intake manifold?).
The rubber hose from the pcv to the metal nipple is fine, and I stuck a plastic zip tie into the metal part as far as I can (until the rubber hose on the back side), and it went in fine. I've tried using a kind of a syringe (normally for measuring premix oil) to apply pressure at the metal nipple, as well as suction, and nothing happens.
Its really hard to get back behind the engine (especially when its hot) to check the other rubber hose, but I'll do that tonight after it cools.
Is this a problem anybody else has experienced? I've searched all over the net and on here and found nothing. The truck drives fine, and no cel, but I don't want this to lead to more problems. I'm good mechanically, but don't know anything about engines.
This is on a 99 v6 ltd 4x4
Thanks in advance
Here goes:
Thanks in advance
