Help Needed!! DRL 2012 TE
capsfan
I just installed some ditch brackets and KC lights, when finished went to check out my new lights and found that my DRL don’t come on anymore note do they come on when in the running light position, they still work as blinkers and also they work when locking and unlocking the truck. I have a 2012 TE a d I kinda like the DRL and just want to know if anyone on here can help at all! Thanks!
Hi capsfan,
Did you tie anything in to the DRL circuit or use any of it's components e.g., wiring, stalk switch, or borrow any of it's ground wires? Can you provide your wiring scheme/diagram for the purpose of analysis? 'Best to you',
rig
We don't know what you did, but you obviously botched SOMETHING. Check your work.
You didn't turn them off, did you?
This is what I did
The only wire that I spliced into on the vehicle was the wiper defrost lamination. Wire to supply my new switch with power when the light stall is turned on. Everything else was wired completely separate and was not tapped into anything on the vehicle. I took a test light and went through all fuses are good, I just really want to know if anyone knows what wire the stalk send power out on for DRL, so I can determine if it’s the stalk switch or something further down the line.
Also what image sites does everyone use? So I can post some pictures of what I have spliced into.
lindwlson982
