Help needed.. RE: Traction control
d2dak
I have about 15k miles on my runner now. I had my car lifted since around 3k miles with the toytec 3/2 spacers. So, I have this problem of the traction control kicking in when i take on or off-ramps that are downward sloped and to the right. If i go above... i'd say 40+ mph.. I also upgraded the suspension about 5k miles ago to OW2.5's, thinking that it would solve the problem, but nope. Anyone have the same problem? or know what i should do? It's kinda scary when it kicks in. I also thought it could be the tires, i swapped them out also.. :mad:
you might need this done:
http://www.toyota-4runner.org/5th-g...celeration-sensor-zero-point-calibration.html
Yeah it seems some people had to do that and some didn't I never had an issue with it but a few others had the same issue you described and the yaw rate calibration seemed to do the trick hope it works out for you.
