help please
10ac
if there is anyone that can help me please text me at 6193222071
i have a TRD brand, NOT the URD 7th injector kit. having problems so if you have installed a TRD 7th injector kit, please text me. id greatly appreciate it.
TRD 7th injector ....
I'm sorry dude I don't have a lot of knowledge here. When did you install the 7th injector, after our SD meet?
Hey Brian, so yes, i actually tried the 7th injector before our meet and had issues with the engine turning over but not starting. Then when i removed the 7th injector ecu's and plug the runners ecu's back up, it starts and runs fine. So i assumed the 7th injector ecu's were bad and then i purchased another set, and they did the same thing. So something isnt right i assume. TRD's 7th injector setup is very easy to install. Only has 1 wire to tap into the stock ecu wiring. Everything else is plug and play.
H.Sikina
