I'm currently trying to replace a couple wheel studs. I have successfully taken everything apart and replaced on the front right tire. I figured I might as well replace the brake pads while I am here.
However. When waiting for a few item in the mail, I started to take apart the drivers side front tire, I cannot for the life of me get the rotor off. I have examined and re examined the successful change, but still cannot get the rotor off on the driver side. I have tried PB blaster over and over, tried heating it up with a torch, tugged and pulled. I have not completely taken the brake caliper off, I have taken the front brake pad. The back pad, and the 2 large bolts holding it to the dust plate are still attached. Also the dust plate is on there. Should I take those off to get more access to the rotor, or am I missing a bolt somewhere??
Thanks,
Andrew
Thanks,
Andrew
