Help! What do I look for in a Used 4Runner 2001
Jeenyus
Hey guys, I'm new here and to Toyotas and I'm about to buy my first 4Runner. I could really use some help on what things I should be listening for/Looking at/Testing while I am on a test drive, also things to look at under the hood and chassis.
I plan on getting a 2001 SR5 4WD with the Sport Package. It has 59k miles and was owned in Virginia for 2 years before being owned here in southern Cali. First owner.
Any and all info and help would be greatly appreciated.
THANKS in advance!
I just bought my runner 2 months ago and i looked at tread on the tires which had 60% left on them.. It is also a sport package runner same year 01. When test driving it. go hard on the breaks just to test if it jerks in rotation as the disc's could be warped so look for that.. grooves in the disc. any bubble spots in paint could be bondo badly used. Carfax the hell out of the car lol.
Plus check for rust anywhere possible because being near Water can cause that. (SoCal) Drive it a good distance and time before buying it. I wouldnt just test drive for like 3 miles and be done. You'll find new problems as you persist.
I was a bit naive but Im in love with my car. Plus if it is a personal seller. Have a mechanic look over it since they wont have a biased opinion and will give you full details on the car.
Hope all this helps and hope you like the runner man!
sweet thanks for the tips dude.
What do you mean you were Naive with your car? You just went head first and bought it?
side note: what does the sports package have that the normal 'Runners don't besides the hood scoop? Better shocks and springs?
thanks again
thanks again
They also had the limited wheels (5-star) although these wheels were not limited to the sport edition only. It also came w/ a SE badge. Some came w/ tube steps like the Xterras but not all did. Otherwise, I think that's it.
don't freak out...
... at all the clicks, clacks, whirs and clunks -- the 2001 T4R owner's manual even states that all these noises are normal and merely indicate the systems are operating; best of luck, I bought my 2001 SR5 (it may have the sport pkg: it's got brush guard, rock rails, 16" star wheels) thru a nonToyota dealer with almost 68K miles + so far no problems except trying to keep it tidy "we're only going for the illusion of clean... " SSD
As stated above, check for rust, soft brakes, and a new paint job (an indication of a previous wreck)
Also, I believe most Sports, if not all came w/ a sunroof. Check for water spots in the headliner around the sunroof and directly below the roof rails. Reason being, I had a '99 4Runner that had leaked in from the roof rail bolts and ruined my headliner before I knew it. Now anytime I'm looking at buying a car, I look at the headliner first!
The Sports also came with color-keyed ft and rr bumpers to match the rest of the vehicle's paint. (Not chrome bumpers like most 4Runners.) The front grille is partially painted as well. Also if you opt for cloth seats on the Sport (instead of leather), it's a two-tone color combination that comes standard. Basically a dark and light gray.
The sport package also has 4:11 gears, bigger brakes, and stiffer sway bars. My wife's '01 Sport rides nicer than my Avalon.
Things I noticed when I bought hers (used):
Don't be too worried about grease slung everywhere underneath. It's a sign that the oil was changed at a shop that knew to grease the driveshafts. If done regularly, there will be grease slung around in the vicinity of the u-joints.
Don't be too concerned about oil buildup on top of the skid plates. The oil filter is accessed through the drivers fender well (the rubber skirt might be missing or loose just to the front of the spring) and when changed in this fashion, you cannot help but lose a cup of oil onto the top of the skid plates. After learning this the first oil change, I started removing the skid plates to change the filter. Takes extra time, but is better than oil spots on the driveway IMO. If you off road, it gives you a chance to pound the dents out too ;-)
The power antenna's had failed on about half of the 4Runners I looked at (in WI, maybe the winters have something to do with it). Her's still works, but needs WD40 regularly.
The fiberglass shroud under the drivers side floorboard was broken on about half of the trucks I looked at, some probably from off roading, and some probably from being on a lift. Again, no big deal.
You can easily check the VIN stickers on every major body part to see if it has been crashed and had parts replaced. They are little silver Toyota stickers on the hood, fenders, doors, hatch, etc, and should all match each other. They cannot be removed without being destroyed, so replacement parts will not have matching stickers. Not that a crashed truck cannot be put back together to a high level of quality, but you should know what you are getting.
If you think the jack is missing, it's under the rear seat, not in the removable panel at the rear like a lot of other SUV's.
Lastly, because of all the hurricanes the last few years, I spent time underneath every truck I drove, sticking my fingers in holes in the frame looking for any sign of mud from flood damage.
These trucks are known for reliability, and as far as I know, there really isn't a history of any common parts failures. As the other poster mentioned, they make a lot of "whirring" & "clicking" sounds, especially right after start up. They all do this, and I think the owners manual even makes mention of it.
Hope this helps. Ours replaced a Chevy Blazer, which replaced a Jeep Cherokee, and I don't think I will ever buy any other than Toyota from here on out.
Scott
heck i didnt even know some of that info about sport edition runners except no skid plate but i wish i had.
oh yea to answer your first question about me being naive
yeah i pretty much did and found small problems here and there.
then some douchebag in a black dodge ram with nerf bar steps desides to pull in too close to my runner and backs out turning the wheel to early to devastate my right rear part of the running board and partial damage to my lower body in front of the rear right fender flare.
Ambrose67
