FanOfSkynyrd
Ok, new member here, been reading through the forums in the past for various things. Now I've run into a roadblock and need some assistance.
It all started when I tried out a bottle of A/C Pro. I live in the Arizona desert, and although the air was blowing cool I thought it could use a boost. Well that turned into a disaster as it did more harm than good. After getting the system serviced (should have done that in the first place) all was good.
We drove out to San Diego and back for a quick summer vacation...all was fine for about a week. I then noticed a rough idle when parked...even more so with the air on, so I thought...oh no, compressor. I took it back to were I got the ac serviced, tech said everything on the ac side checking out good, pressure was good, no leaks, compressor not binding up. He then plugged an OBD scanner in cause the cel was flashing and he asked when the last time I had a tune up. It showed showed p0300, p0301, p0303, p0305, and p0307.
I went ahead a replaced the spark plugs myself yesterday (NGK Laser iridiums). Plugs in there were all Denso's and some looked pretty bad.
Took me about 1.5 hours and after everything fired up like it should. However, after it idles for about 10 minutes I get the following codes: p0300, and p0301-0308...so now saying misfiring on all cylinders.
Any thoughts in what my next steps should be? I'm thinking of cleaning the TB and MAF...but what else could be...the coils, pcv...or something else. Timing belt was changed 40k miles ago.
It's a 2003 sr5 v8 and has about 145k miles on it.
Many thanks in advance.
