Help with e-locker much appreciated
guitarplayer360
I have a 98' 4runner ltd. Bought it with the RR diff lock all set up. Long story, but I ended up having to buy another ECU and switch for the locker. Problem is, the switch and ECU are from a tacoma (has only one grey wire as opposed to a red/blue wire - for a 4runner). I need to match the wires from my new, Tacoma ECU, with the wires from my 4runner's locker's harness.
If ANYBODY, with an ECU for a 4runner can simply look at the wires connecting to their ecu, and read off, in order what color they are, I can simply look at the numbers and match the wires. I would greatly appreciate this.
Thanks in advance. Hope someone can give some help!
Sorry I can't help you, but are you sure it was the switch and ECU that was bad?
I've seen lots of bad elockers, but it always seems to be the actuator (electric motor) on the axle that is the problem.
that helped, but i found this diagram:
http://www.toyota-4runner.org/3rd-g...e-locker-wiring-help-needed-2.html#post780878
anybody have any clue as to what colors the 4,5 and 10 pins are? I know 4 comes from the switch, 5 is power, and 10 is the speed sensor, just not sure which colors these wires should be. I am not worrying about #8, as I am grounding it.
4 is red with black stripe
5 is black with yellow stripe
10 is green with Orange - Speedsensor, not really needed.
