Help With Lug VS. Hub Centric Spacers
surfmobile
So i have a 2006 4Runner. First off I'll start by saying I know 4runners are Hub Centrc i believe. Well I'm running 16" Pro Comp 7098's, which happen to be Lug Centric. When I went to put my Spidertraxxx back on they wouldn't fit with the hub caps on. So i decided to sell the Spidertraxx and run my hub caps. If i want to run spacers again should I be buying Lug Centric one's?
:confused:
I was under the impression that not only is my '08 T4R lug centric bust so were my '00 and '90 T4R's. Anytime I got a chit balance it was because the shop hadn't used the lug adapters. Only with the adapters could I get a half-decent balance.
If you decide to run lug centric spacers let me know... I bought a set then later on went with hub centric. They worked well with regards to wheel balancing but I tow a boat and do some pretty aggressive wheeling, all that force on the lugs rather than the hub started to bother me...
I can't promise how they will work with the wheels you have but i can let them go cheap! PM me if interested!
