Help with Speed Sensor and reverse wire identification
oldenough
I have a 2003 SR5 without JBL system. I am looking to install the Eclipse AVN6620 and from my research so far it is all plug and play other than three wires:
Parking brake signal: which will be grounded to allow function while vehicle is in motion
Speed pulse signal: where is this located on the truck?
Reverse signal: I can just ignore this wire if not using a backup camera, correct?
My other question was in regards to the GPS antenna, has anyone found an easy and effective mounting spot? Thanks
Any update on this?
Parking Brake lt. green - BECU, middle plug, pin 2, I believe it can found in the left drivers kick panel.
This is the VSS wire: VSS wire is purple with red stripe, found in the large bundle of wires right behind the 3 HVAC controls. Any one will do.
reverse sensor: Tap into the drivers kick panel, far left of the fuses. Its a red wire with a yellow stripe.
Yes, fish the wire from the back of the HU, down toward the passenger footwell, up the A pillar, thru the headliner, with the antena (black cube) right behind the rear view mirror. That is where mine is, so far, I have YET to have a weak signal!
Enjoy! :hatsoff:
I just did this yesterday with my 04 Sport Edition with JBL.
I took the GPS wire out of the dash right above the HU where there is a speaker (I went out of the speaker cover edge; even with the wire, the speaker cover still sits down nicely).
Not sure if the non-JBL runners have that center speaker.
The nice thing about that location is that you can't see it from either front seat, but I'm starting to like the A-pillar routing to the rearview mirror. I may try that next time I have it apart.
