hey guys a got a werid problem in a 22re HELP
nashville67
every start up my truck boggs out really bad till it dies it starts idles about 900 then it dropps till the truck dies start it back up does it again :wtf: so i step on the throttle it will remain idleing but really rough like only 2 are firing stand on the gas till WOT it cleans out and idles back down and will do that 3 or 4 times then it will runn normal no boging out no idle problems nothing then shut it down and five seconds later same thing i have changed coil its got new plugs wires cap and rotor and starter there is no cat at all the po cut the exhaust right behind it and punched it out then sold it with no exhaust theres not even a pipe ive wheeled the truck a few times and its gottin a little water in it it dyed hoped out pulled the air cleaner out fired and ran good this by the way was before it started bogging out and one day i went through deep puddle on the way home no attenator took it to the parts store passed but needed barrings new used one passed and in the truck and it was fine for a bit then started acting like this its never been a problem be for oh and iam still getting around 20 miles per gallon with 31s and stock 4.11s
how long ago did it get flooded with water?
first I would check the oil and see what it looks like
check coolant level
if it is milky then do a compression test if not milky then
check fuel pump and filter....
ive done an oil change sense no water in the oil umm it got flooded around june 5 ill go check the coolant level but where the heck is the fuel filter and the distrubtor is all dry
well i went and checked the coolant it was about a quart low and then checked my oil and i got metal shavings in it :redbrick: ****
metal shavings in the oil that's a first...I've never seen that before...try do a compression test and see if they'd your problem
so i cant rent a tester but the girl friends dad has one but i cant figure out the damn fuel filter iam used to seeing the big cans off an older chevy and i dont see any thing like that wht should the compression be on the block
