Hi-Lift Advice
Thai
Elite Member
Hey all,
I am considering to get a Hi-Lift with base. A few quick starter questions:
1. How high should I get it?? 36", 48" or 60"?
2. I assume that CAST is better than Stamped steel...since the price is almost doubled with cast. Considering that Cast Hi-Lift can lift more weight and my G weighs over 5500 lbs, i will probably get cast. Is this correct thinking?
Thanks in advance.
Thai,
I've had my 48" cast one for quite a while and have been lucky to never have used it. I definitely would get at least the 48". Some people say to get the largest you can afford but at the same time I've found that unless you have a lifted rig the 60" can be overkill. Just my opinion.
Scott
Where on the vehicle will you be lifting it, they sell a adapter to lift it at the wheels. The best set-up I had seen was with the combination with sliders.
Koz
Koz, i have sliders on my G.
I have Hanna Quality sliders where I can lift it. I also have an adapter that fits the round tubes and makes it more secure.
Scott
Thai said:
Link no workie for me.
crap im a moron
its wabfaB no G
Please edit your reply...i dont want to make it look like im making fun of him
Thanks!
also, you can get it powdercoated. blingx2
My logic on getting the longest hi-lift was
a) in mud you might need the extra length
b) future suspension mods might benefit a higher lift
c) you might end up on a trail with friends who have higher trucks and need a high lift - what a bonus when you can come to the rescue and get things rolling quickly!
I believe you can also use the hi-lift as a pulling winch but I can't say its a benefit I would of thought of in the buying process.
And yes, the adaptor works killer!
Get yourself a wider base plate too for soft sand/mud applications. They are about three times the area of the standard base and are made of a tough plastic to withstand heavy lifting applications.
If you do get the longest hi-lift note that the standard hi-lift cover bag does not fit well despite it saying that it will fit. I cut the top off mine and extended it by 10" to make it cover the whole length. This was just a test. Now my wife is making me another bag with a few design improvements.
Another consideration is where you intend to mount it. I know some people buy shorter lifts to fit horizontally in a carrier at the rear (or the front) of the truck. I carry mine on the roof using the Yak. Mighty Mounts.
I find I have to remove the baseplate to stop the rattling sound it makes when travelling over even minor bumps. This in part is why we are designing the cover - to eliminate the rattles - which include not only the base plate but the handle too.
Cheers
Mark
