Hi-Lift Jack
Bumbo
Ever since I got a lift, bigger tires... I always worried about changing a tire on the trail and off-road.
Do any of you still run a bottle jack just for the purpose of a tire change? Or is a Hi-Lift jack worth the purchase?
I figured now that I have sliders, the Hi-Lift would be a good addition... but its almost an inconvenience due to its size and I feel like I would need to bring if I bought/owned one... if the OE bottle jack would do the trick I would be pretty ok wit that...
Any tips or opinions for a first time purchase/user?
After about a 3" Suspension Lift and 33" tires you'll barely be able to change the tire on your 4th gen. I tested it on the 4Runner before I installed the current 35's at one point and found that it pretty much was the limit for the stock bottle jack.
Just carry a piece of 4x4 wood to raise the bottle jack, Hi-Lift jacks have their place if you're familiar with their quirkiness. They aren't the safest piece of equipment around.
I've used hi-lifts dozens of times (although not on the 4runner) and think they are awesome. They are faster more versatile than a bottle jack since you can use them for things other than lifting a wheel, but they do have draw backs to consider. Weight and size are the main issues and they can also be dangerous.
I do what CXS just said and carry a few wooden packing plates to give the bottle jack extra height and a larger footprint for soft surfaces.
This is something I've been thinking about and wasn't sure. Thanks for sharing.
Didn't look yet, but seems like there has to be a thread on this (as it tends to be a common topic of conversation), but in the mean time here is my 2 pennies worth.
Used this method for many years until sliders/HiLift:
jackbase.jpg~original
I have a HiLift jack, but would definitely advise to get very well versed in the operations of the jack prior to using, and be extra conscious if on a trail (uneven surface, loose ground/rocks...). I believe they can be very useful/versatile, but they can be dangerous if not used correctly.
Slider adapters (and other add-ons) for the lift can be useful also:
FJLTwithtire-wheelclearancefromgussets_LTpics-Front032.jpg~original
Adding to my previous post and echoing [MENTION=96286]rick13[/MENTION] said, they can be dangerous. I watched a guy who thought he was a Hi-Lift "expert" break an ankle using one. His punishment was driving home to CA from Moab with a manual transmission.:frusty:
charlesz
