Hi Lift Size
ameining
I am wondering what people are running, I ordered the all cast Hi-Lift in the 48" height. I have been debating whether or not I should have gone with the 60" but I just could not justify needing one that tall. I plan on mounting it to the roll bar I installed in the back of the truck, or on the CBI bumper.
Any suggestions, or comments would be appreciated...
The 48" is fine. If you mount it on the CBI, a 60" will stick out really far and you'll probably snag it off road on trees,rocks, etc.. anyways. I can't imagine the 60" will fit inside very easily either. You made the right choice!
Just what I needed, the words from a seasoned vet. Thanks Brian2Sun!!!
Haha, you're welcome! Here's a shot of my 48" Hi-Lift mounted on my CBI. You can see how a 60" would go about to the end of the taillights. I know I would snag it a lot and probably ruin the Hi-lift and the swing-away...
339image007-1.jpg~original
I do love that photo. In the past 9 months I have been staring at the photos on CBI's website in preparation for the purchase. I think I am pulling the trigger on it tomorrow.......While discussing, what are your thoughts on the swing away carrier? I have heard that they can cause the wings can rub the body with the extra weight. I do like the look, not in love with the price.
Thanks, I like that photo too. Actually I sent it to Nathan a long time ago and lost it, then it appeared on the CBI website and I got it back! :trophy:
My "wings" don't rub the body, but when I flex it out, it comes close. I remember COB saying that his flexes a lot too, but he doesn't have a swing-away. The frame itself flexes and so do the body mounts. I know J-money and Driffter's much lighter home-fabbed bumpers flex the same way so there's not much you can do about that. Don't let that stop you from putting a swing-away on it.
Building it yourself would net you the ultimate cost savings, which is what we did. If that is not an option, I would run your bumper wish list by a few local weld fab shops with experience in build bumpers. You'd be surprise what you'll find as well as the cost. It's not rocket science, just takes a skill craftsman. Most will have referrals that you can look at their work. If anything you'll save on the shipping alone going locally, hopefully it's going to be less than $1800 plus
Worth checking into...........hope this helps
Regards........8sm
i cant get the rear tire off the ground with a 48 :(
stick it in the wheel so your not fighting the suspension travel. It works perfect unless your rocking super sweet solid aluminum wheels. That is if your in need of a little rock stack or something. If your changing a tire your best off to use the bottle jack
i dont have a bottle jack can you get your rear tires off with the highlift
not from my bumper back bumper, maybe from the back edge of the slider if i got the high lift almost topped out but i wouldnt trust that. I have had my high lift fall...
but i have a bottle jack :) and a jack stand that i leave in the truck, So i can use the "in the wheel" method then throw a jack stand under the axle. works like a charm! I got tired of changing cv's on the highlift so I always bring a 3 ton jock stand. It fit great in my tool bin.
